2003 Honda CRV Third gear pressure switch
56,000 MILES • 4 CYL • 4WD • AUTOMATIC
IVANKASS
Several weeks ago, the "D" transmission gear light on my dashboard began flashing. It flashed for less than five minutes, stopped flashing and hasn't flashed since.
I asked my mechanic about the flashing light and he said that I need a new third gear pressure switch ($340). Since the light flashed for such a short period and hasn't flashed since, do you think my car needs such a repair?
Thanks for you help.
Nov 28, 2009 at 9:13 AM
HONDA TECH 1818
  • 536 POSTS
Yes, if you don't replace it the trans. will not shift correctly. It's common on the CRVs the 3rd pressure switch fails.
Nov 29, 2009 at 10:06 AM
  • 75,988 POSTS
I don't see any TSB's or Recalls on that 3rd gear pressure switch as a common failure on this vehicle.
Sometimes those idiots lites will come on for no apparent reason and give a person a heart attack thinking there's a major problem and its gonna be a big cost if its not flashing anymore don't worry about if and if you do go somewhere and have it rescanned again
Dec 7, 2009 at 6:08 AM
HONDA TECH 1818
  • 536 POSTS
There's no TSB's or recallls, but I have done alot of those.
Dec 7, 2009 at 1:06 PM
AVERAGEDRIVER
Just replaced mine on my 2004 CRV, took to a reputable transmission shop and paid less than $200. The part itself was about $80. I took it in as soon as the D light began blinking. Don't delay, it's not worth the later hassle.
Jun 30, 2017 at 9:13 AM
