2003 Honda CRV tempature gauge issue and inconsistent heati
48,000 MILES • 4 CYL • 2WD • AUTOMATIC
RLANNON
for a while now when the heat is on the car heats fine when the car is running and then it blows cold air when the car is stopped (i.e. at a red light, in heavy traffic) also I have noticed that the temperature gauge while in traffic rapidly rises to the top of the gauge and I am fearful the engine could be about to overheat, usually in such situations with other vehicles turning on the heat (even in summer tends to lessen the temperature gauge to a lower level but that does not occur in this situation
Mar 10, 2009 at 1:17 AM
KHLOW2008
  • 41,812 POSTS
Hi rlannon,
Seems engine is overheating due to insufficient cooling and possible causes are :
1. Insufficient coolant. Did you check the coolant level in radiator? Do it whan engine is cold.
2. Cooling fans not working. Are both radiator and condenser fans working?
Mar 10, 2009 at 6:47 AM
