2003 Honda CRV PCV valve
83,000 MILES • 4 CYL • 2WD • AUTOMATIC
PETER_BAB
where is the PCV valve located on the 03 honda CRV
Jun 15, 2010 at 3:46 AM
The PCV is located in the front passenger side of the engine, and I am attaching a number of documents that will help with finding it and replacing it.
PCV can cause a number of issues including a high idle if it is stuck open. Also, it can cause oil in the intake if you have high amounts of blow by.
https://www.2carpros.com/articles/engine-idles-too-high
Please run through the info below and let me know if you have questions.
Thanks
May 28, 2022 at 9:15 AM
