2003 Honda CRV grinding noise
160,000 MILES • 4 CYL • 4WD • AUTOMATIC
ARCHIDUCKT78
Just wondering if it might be the brakes or cv joints, but when I turn sharp, ie turning into a parking place and/or have to turn the wheel almost all the way, there's a noise that sounds like gringing or rubbing hard. Wondering what you might think it is and if this might be something I should get checked immediately? Also having transmission problems and engine light has been on for about a month or two.
Dec 10, 2009 at 1:41 AM
HONDA TECH 1818
  • 536 POSTS
The rear differential fluid needs to replace, when the fluid is contaminated or is dirty the differential makes rubbing and grinding noise when making sharp turns. Use Honda dual pump fluid for the differential.
Is the D light flashing?
Dec 12, 2009 at 6:43 PM
