2003 Honda CRV Brake rotor flat-head screw removal?
2003 HONDA CRV
108,000 MILES • 4 CYL • AWD • AUTOMATIC
BOOGITY
Honda uses two flat head machine screws to hold the brake rotors in place on the CR-Vs. These screws are always corroded and since they are Phillips and mild steel, they are almost impossible to remove when replacing rotors.
Do you guys have any suggestions on how to remove these screws without damaging the screws or having to drill them out?
Thanks, Boogity[img:01c6653a86]http://www.2carpros.com/forum/automotive_pictures/176712_brake001_1.jpg[/img:01c6653a86]
Apr 8, 2008 at 12:40 AM
BRUCE HUNT
  • 3,754 POSTS
Yes I do. It is a rather cheap tool and you will not use it a lot but when you do it is very handy. It is an impact driver. It has a end that you rap with a hammer and the other end has removable bits for various attachments. A click one way or the other and it will either tighten the screw or loosen it. Insert it firmly in to the head of the screw and hit it with hammer. Wa la. It works.
Harbor Freight, auto parts store, tractor supply stores care this tool. Good luck.
Feb 20, 2021 at 4:33 AM
