2001 Honda CRV rotors
2001 HONDA CRV
15,000 MILES • 4 CYL • 2WD • AUTOMATIC
JOHNNYMCKNIGHT
how do I remove center nut to get rotor off?
Nov 19, 2009 at 8:38 PM
SERVICE WRITER
  • 9,123 POSTS
You don't need to pull the axle nut off. The rotors are slip on style.
https://images.2carpros.com/forum/automotive_pictures/30961_748600_1.jpg
The rotor may be seized to the hub and may require some forceful hits with a hammer to remove. Spraying a quality penetrating lube may help at the points around the studs.
Feb 20, 2021 at 4:34 AM
