2003 Honda CRV alarm
30,000 MILES • 4 CYL • 4WD • AUTOMATIC
DEDONK
my alarm has been coming on today after AA recommendation my batteries was low when they were called.
When battery was replace, the alarm system came on a for over 15 minutes and would not turn off, I am afraid I might lose battery power and my guarantee would not be covered, if this happen again. this is first time it has nr happen.
What would you recommend
Oct 30, 2010 at 5:55 AM
KHLOW2008
  • 41,812 POSTS
Hi dedonk,
The alarm would not be triggerred if the battery is low unless you try to crank the engine.
If the alarms is self trigggering, check the doors and hood switch. If they are out of adjustment, the alarm can be triggerred due to vibrations causing the switches to come into contact.
Oct 30, 2010 at 7:43 AM
