2002 Honda CRV grinding sound
72,000 MILES • 4 CYL • 2WD • AUTOMATIC
JOHNARCI
THe air conditioner works as far a cooling. In fact it is cold as I replaced the compressor recently. However the thing is making a winding almost grinding sound which coinsides with the transmission sound. When the air conditioner is turned off, the sound disappears. Clutch in air conditioner??
Oct 6, 2008 at 4:07 AM
KHLOW2008
  • 41,812 POSTS
Hi johnarci,
It should not be the AC clutch as when clkutchis engaged, it moves as a unit. More likely the noise is from the compressor internal bearings or pump and the compressor is showing signs of failing.
It is cold because pressure is still ok but the bearings are going.
Oct 14, 2008 at 6:21 AM
