Engine stalls at stop or while driving
2002 HONDA CRV
FEASTMAN
I have an 02 CRV that has developed a stalling issue. When driving the "D" indicator will go out and the engine loses power. Power returns after a few moments and the "D" indicator comes back on. It has also stalled when approaching a stop. Things like radio, wipers, etc. don't drop out and the dash lights do not come on as if the ignition as been turned off.
Sep 2, 2010 at 9:08 AM
KHLOW2008
  • 41,814 POSTS
Hi feastman,
Symptoms indicates the ignition switch is faulty. There was a safety recall on the item and you can call the nearest dealer for more details.
Mar 29, 2021 at 10:03 AM
FEASTMAN
I replaced the ignition switch as suggested and the following day the symptoms returned. Any other thoughts?
KHLOW2008
  • 41,814 POSTS
The D4 indiator light going off indicares a power supply interruption. Since the interruption is not from the ignition switch, you would need to check the connections between the ignition switch to the fuse box.
Unplug the connectors at the fuse box and look out for signs of overheating or contaminations.
LARA VAN POECKE
Hi I am currently having the same problem with my car, did you end up finding a solution?
  • 54,840 POSTS
I am not sure they will answer but I will help you. can I ask if the check engine light is one and if so here is a guide to help us get the codes and to check out the easy stuff:
and
https://www.2carpros.com/articles/stall-at-idle
