Can't tell from here. The computer in your Honda has detected a problem and is letting you know with the check engine light. You need someone to plug in an engine scanner to pull the code and see what made the light come on.
A lot of auto parts stores and repair shops will pull this code for you at no cost. Then you will know what to fix or have fixed.
Oct 29, 2008 at 4:29 AM
