It shows a DTC P0780.
MTBOAXACA
Transmission problem
2002 Honda CRV 4 cyl All Wheel Drive Automatic
Hello I have a 2002 crv awd with automatic 4 spd. trans. It shows a DTC P0780. When the car is cold for 5 min. it will shift ok. After that from 1st to second I need to let up a little to allow the shift or it will rev out and not shift. A few minutes later the "D" light blinks and the trans. goes into a neutral mode even though its in drive. I can shut it off wait a minute or so then restart the car. The trans. semi functions to drive back home before it goes into neutral mode again. The trans. fluid is new and topped off. The car has 90k miles on it. Bad solenoids?
Jul 22, 2010 at 8:31 AM
KHLOW2008
  • 41,812 POSTS
Hi mtboaxaca,
P0780 = Mechanical problem in hydraulic control system.
DTC P0780: MECHANICAL PROBLEM IN HYDRAULIC CONTROL SYSTEM.
NOTE:
This code is caused by an electrical circuit problem and cannot be caused by a mechanical problem in the transmission.
Keep replacement solenoid valves on hand;
i. A/T clutch pressure control solenoid valves A, B, and C
ii. Shift solenoid valves A, B, C, and E.
1. Check whether the scan tool or the HDS indicates another code.
Does the scan tool or the HDS indicate another code?
YES - Perform the troubleshooting for the indicated code(s). Check for DTC P0780 after troubleshooting.
NO - Go to step 2.
2. Turn the ignition switch OFF.
3. Replace A/T clutch pressure control solenoid valve A
4. Replace A/T clutch pressure control solenoid valves B and C
5. Reset the PCM memory by removing the No. 6 ECU fuse (15A) in the under-hood fuse/relay box for more than 10 seconds.
6. Drive the vehicle for several minutes in 1st, 2nd, 3rd, and 4th gears in the D position, and stop the vehicle. Do not stop the engine.
7. Repeat step 6 five times.
8. Recheck for DTC P0780.
Does the scan tool or the HDS indicate code P0780?
YES - Go to step 9.
NO - The problem has been corrected.
9. Turn the ignition switch OFF.
10. Replace the shift solenoid valves A, B, C, and E
11. Reset the PCM memory by removing the No. 6 ECU (15A) fuse in the under-hood fuse/relay box for more than 10 seconds.
12. Drive the vehicle for several minutes in 1st, 2nd, 3rd, and 4th gears in the D position, and stop the vehicle. Do not stop the engine.
13. Repeat step 12 five times.
14. Recheck for DTC P0780.
YES - Go to step 15.
15. Turn the ignition switch OFF.
16. Remove the transmission, and overhaul transmission hydraulic control system.
17. Install the transmission on the vehicle.
18. Reset the PCM memory by removing the No. 6 ECU (15A) fuse in the under-hood fuse/relay box for more than 10 seconds.
19. Drive the vehicle for several minutes in 1st, 2nd, 3rd, and 4th gears in the D position, and stop the vehicle. Do not stop the engine.
20. Repeat step 19 five times.
21. Recheck for DTC P0780.
YES - Replace the transmission assembly.
This problem is usually caused by a turbine speed sensor failure.
Here is a video showing you how to replace it.
https://youtu.be/f3bETtCIdxM
Make sure you clear the codes after
https://www.2carpros.com/articles/check-engine-light-clear-codes
Please let us know what you find.
Cheers,
Jul 23, 2010 at 3:08 AM
MTBOAXACA
That worked! you guy are the best I love this site. Saved me a ton of $$
Jul 23, 2010 at 4:18 AM
ALOHA168
  • 52 POSTS
MTBOAXACA What part(s) did you replace to fix it.Please answer because I have the same car with similar problems.Thank you.
Oct 31, 2024 at 8:53 AM
  • 55,616 POSTS
This post is 14 years old IDK if they will respond.
Nov 2, 2024 at 1:23 AM
