2002 Honda CRV Code P1158 wont go off
83,000 MILES • 4 CYL • AWD • AUTOMATIC
SCHNEBBLES
I put a new front oxygen sensor on (generic) - brand name was Replacement. Now I have code P1158 and it won't go off - it's been a week. What do I do?
Jun 17, 2009 at 7:26 AM
KHLOW2008
  • 41,812 POSTS
Hi schnebbles, Thank you for the donation. Honda do not take kindly to some generic sensors so it could be the cause. Here are the diagnostic procedures for the code.
https://images.2carpros.com/forum/automotive_pictures/192750_DTCP1158_02CRV01a_1.jpg
https://images.2carpros.com/forum/automotive_pictures/192750_ECM31Connector02CRV_1.jpg
https://images.2carpros.com/forum/automotive_pictures/192750_DTCP1158_02CRV01b_1.jpg
Jun 17, 2009 at 8:50 AM
SCHNEBBLES
Hi - the code P1158 said mfg controlled fuel & air metering. Does this make a difference?
We unplugged the battery last night and the code temporarily went off but came right back on.
Jun 23, 2009 at 3:03 AM
KHLOW2008
  • 41,812 POSTS
The actual code is the one that I have provided.
Some generic scanners do not have the complete fault list and for any that is not within their database, it would be given as a general statement of mfg controlled fuel & air metering.
Check if the sensor that you replaced had the wires correctly installed and perform the test accordingly.
Resetting would not solve the problem if a fault is present.
Jun 24, 2009 at 1:07 AM
