2002 Honda CRV ceck ingin light
2002 HONDA CRV
120,000 MILES • 4 CYL • FWD • AUTOMATIC
SINISA
code p1456 i called for this problem one of your mechenics tolld me to replased ges tenk cap it did not work i still have same problem .i took my car to mechenic he run the test and tolld me ;my evap emission control system leak detected (fuel tank system) evap two-way/bypass solenoid valve bad.
Can you tellme where is this part located and how to replase it if you think thet is the problem
May 29, 2010 at 8:11 AM
The evaporative bypass solenoid valve is located on left rear of fuel tank
May 29, 2010 at 11:10 AM
