Caliper hanging up or brake hose collapsed. Caliper pins o.K.? When you remove caliper, pull out the two pins in pad saddle & make sure they are free. Lube w/caliper grease. Are the pad slots cleaned up so you can take pads out & put in w/ fingers? They need to float freely and pins need to slide in & out freely.
SPONSORED LINKS
Friday, May 8th, 2009 AT 8:47 PM
