Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Honda
CRV
Brakes
Rotor
Replace/Remove
2001 Honda CRV rotors
2001 HONDA CRV
15,000 MILES • 4 CYL • 2WD • AUTOMATIC
JOHNNYMCKNIGHT
MEMBER
1 POST
how do I remove center nut to get rotor off?
Nov 19, 2009 at 8:38 PM
SERVICE WRITER
Experienced Mechanic
You don't need to pull the axle nut off. The rotors are slip on style.
The rotor may be seized to the hub and may require some forceful hits with a hammer to remove. Spraying a quality penetrating lube may help at the points around the studs.
Feb 20, 2021 at 4:34 AM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Check engine light
