2001 Honda CRV Noise in front end
109,000 MILES • 4 CYL • AWD • AUTOMATIC
BUCKEYE77
Everytime I brake, start from stop, or turn going slow speeds I get a loud noise in the front end. It sounds like it is underneath. It sounds like metal grinding. Any ideas? It also makes the noise when I am sitting still and turning the steering wheel from left to right. It makes the noise around 85% of the time.
Signed,
Clueless in Ohio
Mar 9, 2009 at 3:46 AM
KHLOW2008
  • 41,812 POSTS
Hi buckeye77,
The symptoms described indicates a bad lower control arm ball joint if the disc pads are not worn. Check if the backing plate is too near the rotor.
Mar 10, 2009 at 6:42 AM
