did not run (installed new coil )car would start ,noticed antifreeze blow by at radiator found water pump bad (changed the water pump and timing belt) car still had misfire checked compression number 2 cyl low (did head gasket ) still have misfire (did plugs ,cap,wires,rotor,checked fuel psi ) still have misfire when warmed up (my next try would be ignition module) does any one have a better idea??????
Jan 6, 2010 at 12:43 AM
