Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Honda
CRV
Drivetrain
Wheel Stud
Replace/Remove
FRONT WHEEL STUD
2001 HONDA CRV
LUNTIRE
MEMBER
How can I change a broken wheel stud on the front wheel?
Jan 28, 2009 at 3:51 AM
F4I_GUY
Experienced Mechanic
This one will take some doing first you need to remove the spindle and hub here is a guide to show you how this guide has most of the steps
https://www.2carpros.com/articles/how-to-replace-a-cv-axle-bearing
You will need to undo the tie rod as well.
https://www.2carpros.com/articles/tie-rod-end-replacement
Then once the hub is apart then you can replace the wheel stud.
https://youtu.be/LSZ8P0wrQX8
Cheers
Images (Click to enlarge)
Mar 7, 2009 at 6:12 AM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Check engine light
