2001 Honda CRV delay engaging into drive
AQSRADDAD
Transmission problem
2001 Honda CRV 4 cyl All Wheel Drive Automatic
when the car is put into drive (forward) there is a 1 - 3 second delay before the transmission engages. it is the only gear this issue occurs with it engages instantly when put in reverse. i have made sure the fluid levels are where they are supposed to be so i am hopeing this is a sensor or something less complicated that transmission failure.
Sep 27, 2010 at 1:23 PM
  • 75,988 POSTS
Hi AQsraddad, Welcome to 2carpros and TY for the donation.
Are you checking the transmission fluid while the engine is idling and up to operating temperature-best way to check it is drive around for atleast 15mins and check it again while engine is idling-could be a transmission problem-
Have this 2 sensors checked out -throttle position sensor and vehicle speed sensor the computer uses it as an indications of throttle and governor pressure to command and control the upshifts/downshifts/lock-up
Sep 27, 2010 at 8:07 PM
