2001 Honda CRV Compressor Replacement
2001 HONDA CRV
98,000 MILES • 4 CYL • 4WD • MANUAL
YADAMIR
Okay... so my air conditioning compressor exploded... yep, exploded. The casing has a large hole in the side of it. So, I need to replace it.
So here is my question: It is my understanding that in such circumstances, it is imperative that the cooling system be flushed to remove any foreign objects to insure that the same situation will not happen again. How is this done? Can it be done by a novice mechanic such as my self, or do you recommend having the compressor replaced by a repair shop? Also, is it harmful to the vehicle to drive it with a broken compressor? It is my understanding the the clutch has a safety mechanism that doesn't allow the clutch to engage in such a case.
I am trying to get this repaired as cheaply as possible, so if anyone can help me out I would appreciate it!
Jul 23, 2008 at 5:19 AM
KHLOW2008
  • 41,814 POSTS
Hi yadamir,
The reason your compressor exploded could be due to lack of lubricants, etc and the system could be contaminated so it is recommended that a flush be done before the new system is installed.
Driving with the dead compressor is ok but there might be others waiting to come off and that could cause more damage.
DIY is not easy to handle the situation unless you have some experience and the required tools and equipments.
Jul 30, 2008 at 4:31 PM
