2000 Honda CRV Whistling Noise
132,333 MILES • 4 CYL • 4WD • AUTOMATIC
SPOWER52
Noise appears at random and I cannot associate it with anything other than some engine component. Does not matter if engine is hot or cold. And, it does not sound like a worn/bad bearing. Sounds similar to the noise my daughter's car made when the PCV valve was bad. She has a 2004 Honda CRV.
Dec 10, 2009 at 8:04 AM
  • 31,937 POSTS
HI there,
A whistle can usually be associated with a vacuum leak, you can check around manifolds with a length of hose to your ear, this will soon pick up any leak, check this first.
Mark, (mhpautos)
Dec 10, 2009 at 8:52 AM
