2000 Honda CRV P0300 And other misfire codes
130,000 MILES • 4 CYL • 2WD • AUTOMATIC
JNKCONNER
It came in for a check engine light producing a low voltage o2 code, After shutting check engine light off, right off the bat it popped up cylinder 4 misfire and Random misfire codes,
So we start with well over due plugs wires cap and rotor, Reset light, and before we could get it into gear, WAMO!! Same problem, however its not running all that rough for having a miss on atleast 2 cylinders, Fuel filter is oe and injectors are good,
I think the fuel filter is the purp,, will check fuel pressure monday,, Sound about right ???
May 2, 2009 at 1:47 PM
  • 75,988 POSTS
Engine misfires can be caused by worn or fouled spark plugs, a weak spark (weak coil, bad spark plug wire), loss of compression, vacuum leaks, anything that causes an unusually lean fuel mixture (lean misfire), an EGR valve that is stuck open, dirty fuel injectors, low fuel pressure, or even bad fuel.
May 2, 2009 at 11:02 PM
