2000 Honda CRV Oxygen Sensor/Catalytic Converter
2000 HONDA CRV
167,000 MILES • 4 CYL • AWD • AUTOMATIC
DSRTDUG
My Honda CR-V had a bad catalytic converter so I replaced it with a good after market brand for around $500. The check engine light came back on again with the following code P204 Something to do with improper flow thru the converter, I replaced the O2 sensor towards the back tail pipe end of the cat. converter. Still I get the check engine light. Does the computer have to be reset by a Honda tech to recognize the non factory catalytic converter. Is something else causing the code to go off? At my wits end! Any help would be greatly appreciated!
Thanks Doug
Feb 11, 2010 at 11:17 AM
KHLOW2008
  • CAR REPAIR CONTRIBUTOR
  • 41,814 POSTS
hi Doug,
I believe your are referring to P0420 and not as indicated. Some after market catalytic converters do not match up and would cause the coede to return even if it is new.
Here are the diagnostic procedures and what to check first.
DTC P0420: CATALYTIC SYSTEM EFFICIENCY BELOW THRESHOLD
NOTE:
If DTCs P0137, P0138, and/or P0141 are indicated, trouble shoot DTC P0420 last.
NOTE:
DTC P0420 is set and MIL illuminated when malfunction has been detected during 3 consecutive trips.
1. Perform PCM reset procedure. Start engine and run at 3000 RPM with no loads and transmission in Park or Neutral until radiator fan comes on. Connect SCS service connector (07PAZ-0010100). Test drive
vehicle at 40-55 MPH for about 2 minutes. Decelerate for at least 3 seconds with throttle
fully closed.
2. Reduce vehicle speed to 35 MPH, and hold it there until readiness code comes on. If DTC P0420 is not indicated, problem is intermittent. System is okay at this time. If DTC P0420 is indicated, inspect Three Way Catalytic Converter (TWC) for plugging, melting, cracking, or exhaust system leaks. Repair or replace TWC as necessary.
© 2008 Mitchell Repair Information Co., LLC.
Feb 14, 2010 at 6:08 AM
