2000 Honda CRV Engine Fan
2000 HONDA CRV
180,000 MILES • 4 CYL • 2WD • AUTOMATIC
THAO117
Hello, my 2000 Honda CRV's fan only engages when the engine's temperature is about to hit critacal (almost all the way up to the maximum on the heat gauge). Once it gets to that point the fan begins to work and the temperature goes back down. I already replaced the thermostat with a new one. The season right now is fall in the midwest and the temperature outside is usually about 50-60 degrees fahrenhiet. What could the problem possibly be?
Sep 11, 2010 at 12:54 PM
F4I_GUY
  • 3,302 POSTS
Sounds like the fan switch is getting dirty and acting lazy. I would repalce the fan switch and see if that helps.
Sep 13, 2010 at 12:12 PM
