When I turn right at slow speed get noise from front end, like a chattering noise
May 30, 2008 at 5:31 AM
BLACKOP555
✓Experienced Mechanic
could be a outer cv joint isure, also could be a wheel bearing issue, best way to check cvs is try drive slowly in reverse and turn left and right with windows unrolled, if they are bad you will hear a ticking noise
to check wheel bears, jack up the front end and feel for play in the wheel.
