1999 Honda CRV Won't stay running
132,000 MILES • 4 CYL • AWD • AUTOMATIC
LITLDEVIL88
The truck has been running fine until yesterday when it started runnung at a low idle then had to keep pushing on the gas to keep it running then would stall., finally it would just die after a few seconds everytime started. Changed the fuel filter and ran fine for one outing then back to the same problem. I'm thinking it might be the fuel pump but i'm no expert. Last year in the winter it would have problems starting sometimes but once started it would run fine. Wasn't sure if this mattered. Thank-you
Nov 18, 2009 at 11:39 PM
KHLOW2008
  • 41,812 POSTS
Hi litldevil88,
Thank you for the donation.
The problem should be with the idling system and the most common cause is a dirty throttle body, idle adjust screw air passage and the IAC. Get them cleaned and readjust the idling speed and problem should be resolved.
Nov 19, 2009 at 2:51 AM
