1999 Honda CRV Shaking during acceleration
119,000 MILES • 4 CYL • 4WD • AUTOMATIC
DOUGDDIVER
My car has been at the repair shop for a few weeks. I was noticing a shaking only during acceleration. They tried swapping out the axels but that didn't fix the problem. they also said the mounts seem to be ok. They are at a loss for what is causing the shaking.
Thanks
Jun 9, 2010 at 12:23 PM
KHLOW2008
  • 41,812 POSTS
Hi dougddiver,
At what speed does the shaking occurs?
Were the propeller shaft U-joints checked?
Jun 10, 2010 at 1:45 AM
DOUGDDIVER
The mechanic said he disconnected the rear drive line and replaced the fron drive line, but did not fix the problem. Would replacing the front drive line include the drive shaft?
Thanks
Doug
Jun 21, 2010 at 5:16 AM
KHLOW2008
  • 41,812 POSTS
Replacing the front drive line should mean the driveshafts.
Any specific speed range?
Jun 21, 2010 at 6:17 AM
DOUGDDIVER
From what I can remember, I think it was shaking during accleration from lower speeds, but maybe a little at higher speeds but was not as noticeable as from a stop.
They have had it at the shop for over a month so it I can't remember exactly.
Thanks,
Doug
Jun 21, 2010 at 6:23 AM
KHLOW2008
  • 41,812 POSTS
Symptoms indicates a possible fault with the drive trains, ie drive shafts or the transmission.
Check the driveshaft inner joints for excessive side play. If the joint that goes into the trans has excessive side play, the differential is possibly bad.
Jun 21, 2010 at 7:14 AM
