1999 Honda CRV Check Engine Light
12,900 MILES • 4 CYL • 4WD • AUTOMATIC
PATTIPEA14
Funny, I just made an appt. to take my car in to have the timing belt changed and water pump, Now the Check Engine Light just came on out of the blue?
Also, the a/c is broken any suggestions how to get it fixed?
Sep 12, 2009 at 9:54 PM
  • 31,937 POSTS
Hi there,
The ECU will require a diagnostic scan to determine the code indicated by the check light, this will need to be know first so the potential trouble area can be determined, as for the A/c this will also need to check by a tech, but the most common cause for this is low refrigerant due to a leak in the system.
Mark (mhpautos)
Sep 12, 2009 at 10:51 PM
