1999 Honda CRV broken lug bolts
KINGBRINKS
1999 Honda CRV
how to replace broken lug bolts on front hub..
May 27, 2010 at 4:00 AM
KHLOW2008
  • 41,812 POSTS
Hi kingbrinks,
You would have to "
1. Remove the brake caliper and mounts.
2. Remove the brake disc.
3. Remove the CV joint central nut.
4. Pull the hub out wlightly with a puller.
5. Knock the lug nuts out and install new ones.
6. You can uses the lug nutds with appropriate spacers to tighten to press the lug nuts back in.
May 27, 2010 at 8:11 AM
