1999 Honda CRV
HOTCHICK101
1999 Honda CRV Automatic
I had my car engine head skim but now it is making load noise like an old truck so I adjust the vale to 8mm but it is still making noise. What is the correct valve adjustment and could there be a another reason for the noise when idle as well as while driving also when the a/c is on it make more noise and start to jump?
Sep 28, 2008 at 2:06 AM
KHLOW2008
  • 41,812 POSTS
Hi hotchick101,
Valve adjustment should be done with engine cold.
Intake = 0.08 - 0.12 mm
Exhaust = 016 - 0.20 mm
Excessive noise could be due to improper timing belt adjustment, a slack timing belt would cause a lot of noise.
Oct 14, 2008 at 2:48 AM
