1999 Honda CRV 4 cyl All Wheel Drive 208000 miles
MY CAR IS IN 3 CYLINDERS INSTED OF FOUR A FRIEND TOLD ME THAT THE PROBLEM ARE THE VALVES AND THE SCANNER SAID THE SAME BUT I WANT TO MAKE SURE THAT IF I CHANGE THE VALVES THE PROBLEM IS GOING TO BE SOLVE NOW THE COMPRESSION IS IN 25 PSI DO YOU THINK THAT IS THE PROBLEM OR DO I HAVE TO CHANGE THE MOTOR COMPLETLY OR REBUILD IT?
Wednesday, May 5th, 2010 AT 12:24 AM
