This is due to the tires not being worn evenly. So, we need to start with inspecting the tires and here is a guide that will help with this:
https://www.2carpros.com/articles/how-car-tires-work
I am also attaching the chart below which will show more info on what to inspect.
The reason the steering wheel is not centered with these tires and not the others on the front, is because the tires are different circumferences and that will cause the wheel to lean to the smaller size. This means we should most likely replace both front tires and it would be a good idea to have the vehicle aligned so that you don't create wear issues on the new tires.
Please run through this and let me know what questions you have. Thanks
Image (Click to make bigger)
Wednesday, December 8th, 2021 AT 2:43 PM
