1998 Honda CRV squealing noise with sharp turns at low spee
13,000 MILES • 4 CYL • AWD • AUTOMATIC
LGP0728
When I make sharp turns at low speeds, like turning 90 degrees into a parking space, my car makes a high pitched squealing sound. I do not get the same noise with sharp turns in reverse, like backing out of a parking space, or with larger angle turns. It be my imagination but it seems that the problem may be greater with left turns.
Nov 30, 2009 at 1:42 PM
HONDA TECH 1818
  • 536 POSTS
The Differential fluid cause be contaminated, replace the fluid with Honda Dual Pump fluid.
Nov 30, 2009 at 1:53 PM
