Keep engine and other components serviced at every recommended schedule which is located in your owner's manual. If you do not have an owner's manual then you can contact your local Honda dealer and ask them for their recommended services for your vehicle at specific mileage intervals. Changing your engine oil/filter and coolant system are the two most critical maintenances to prolong your engine's life. Fuel additives such as STP Fuel Injection/Carb. Cleaner and STP Fuel Treatment are a great way to keep the water and other gunk out of the fuel and also keep the carb. Or fuel injectors clean.
Thanks for using 2CarPros. Com!
SPONSORED LINKS
Tuesday, February 3rd, 2009 AT 11:00 AM
