1998 Honda CRV Car stop running
HONDA-CRV-1998
  • 1998 HONDA CRV
  • 4 CYL
  • AWD
  • 113,000 MILES
CRV 1998 just suddenly stops running whille driviing and than the car wouldn't start. After a while it can start and go fine. It happens like an instant shut down of all car systems. Bettry is fine
Monday, November 30th, 2009 AT 1:58 PM
KHLOW2008
  • 41,814 POSTS
Hi honda-crv-1998,
When engine shut down, if the dash indicator lights were not showing, the most likely cause would be the ignition switch. There was a safety recall on the item and you can check with your nearest honda for more details.
If the dashlights are indicating, check the PGM-FI main relay and fuel pump, eiter one could be malfunctioning intermittently causing the stalling and no start condition.
Wednesday, March 17th, 2021 AT 12:12 PM
