1998 Honda CRV car shuts off while driving
CHAZLINKS
  • 1998 HONDA CRV
  • 4 CYL
  • AWD
  • 97,000 MILES
My 98 CRV honda continues to completely shut off while I am driving. This only happens when the car has warmed up and also when carrying approx. 80 extra lbs in addition to the driver. The thermostat appeared broken and was replaced this past Monday, this did not fix the problem. Everything on the car will shut off, electrical, motor and power steering.
What could be the cause of the shut downs?
Wednesday, April 22nd, 2009 AT 11:55 AM
KHLOW2008
  • 41,814 POSTS
Hi chazlinks,
The most likely cause would be a faulty ignition switch. When vehicle cuts off, are the dash lights showing?
Wednesday, March 17th, 2021 AT 12:12 PM
CHAZLINKS
Thank you for your reply.
When the crv shuts down everything goes. Dash lights, motor, power steering. The works.
I can bring all electrical back up immediately. Typically, I need to wait several minutes to get car started again.
Chazlinks
KHLOW2008
  • 41,814 POSTS
I would suspect a faulty ignition switch. It fails intermittently due to heat and this item fails quite often over time.
