1998 Honda CRV burned valve?
250,000 MILES • 4 CYL • AWD • AUTOMATIC
JMCKERNAN
Engine is running rough with the engine light blinking did test at Honda dealer and they said burned valve and a tune-up will not help it. one cylinder appears to have burned valve and not firing. Can a tune-up fix this problem or do I have to do a valve job and/or replace the engine?
Aug 13, 2009 at 1:04 AM
F4I_GUY
  • 3,302 POSTS
You need to replace the valves, purchase a new head or a new engine.
Aug 14, 2009 at 1:56 PM
BUDA_1
I feel your pain. The exact same thing is occuring to my 1998 CRV with 105,000 miles. (litterally right now (8/27/09) the car is at the shop) I've already done a cap, rotor, wires, plug swap but still check engine is flashing.
Brought it to a garage was sorry to hear valve issues are a common problem with the 98-01 models. I am hoping a valve adjustment will rectify the issue but all signs point to a valve job being needed. I will of course do the timing belt/water pump if it is determined the valve job is needed.
I am suprised to hear you have 250K on the car. I would junk it if I had that many miles (considering my work (if valve job) will be ~$1500).
Too bad these cars have this issue, it was a good running car just can't see disposing of it w/ only 105K
Aug 27, 2009 at 12:11 PM
BURNEYS
I have a crv with over 350K miles they last and last don't junk it.
Jan 31, 2023 at 3:12 AM
