When making a sharp turn, or u turn, the car shakes until you straighten the wheels..It seems like the 4 wheel drive doesnt release. Solution?
Jul 1, 2009 at 2:13 AM
KHLOW2008
✓Experienced Mechanic
Hi markallenstudio,
Quite often this happens when the differential fluids requires replacement.
The correct type of fluid must be used failing which it would judder when making full turns.
Jul 1, 2009 at 3:02 AM
MARKALLENSTUDIO
MEMBER
Is the differential fluid change doable by a handy car owner?
Jul 1, 2009 at 6:06 AM
KHLOW2008
Yes, the job can be done easily.
Just drain and fill.
Recommended fluid is Honda Dual Pump System Fluid ( DPSP II ) P/N 08200/9002 )
Fluid change capacity is 1.0 liter. ( 1.1 US quart )
Jul 2, 2009 at 2:36 AM
MARKALLENSTUDIO
MEMBER
How many differentials are there where one would change this fluid?
Jul 2, 2009 at 3:24 AM
KHLOW2008
The front differential is incorporated into the transmission assy. The rear differential is a separate unit which is the source of grating noises when making full turns when fluid quality deteriorates.
Jul 2, 2009 at 6:21 AM
KAYE
MEMBER
Recently took a trip and the car started to buck. Used Injection cleaner seemed to do fine. Got gas in Jolly, TX and about 1hr later started doing the samething but worse. Now it bucks on occasion and the check engine light flashes which never has done before. Please help.
Images (Click to enlarge)
Apr 17, 2019 at 11:48 AM
(Merged)
KHLOW2008
Get a scan done to retrieve the trouble code for the MIL indicating and let me know the EXACT trouble codes.
Most parts stores provides the scanning services.
(Merged)
KAYE
MEMBER
Ok here is what we found very bad spark plug. 2nd from the right was black, broken and the where the point is the curved part was totally gone. What causes that?
(Merged)
KHLOW2008
That could be due to misfiring or a bad catalytic converter. What was the trouble code retrieved? It could throw a light on the problem.
(Merged)
JCTURNER1973
MEMBER
1 POST
This part just got knocked off my vehicle. Can someone tell me what it is and what it is does?
(Merged)
HONDA TECH 1818
It's a rear differential damper and is designed to keep the vibration down generated by the differential. Please let us know if you need anything else to get the problem fixed.
