1998 Honda CRV
PAMELA B
  • 1998 HONDA CRV
  • 4 CYL
  • AWD
  • 174,000 MILES
My air conditioning works most of the time but occasionally it quits producing cool air. This will correct itself within about a minute. The temperature light stays stable whether it's cool or warm air. I've only noticed this while traveling rather than idling but don't know if that's significant since I'm traveling most of the time. Any suggestions appreciated.
Monday, June 30th, 2008 AT 7:08 PM
BMRFIXIT
  • 19,053 POSTS
Under load AC compressor will shut down
its a normal operation of the car and nothing can be done on
if not under load check system for over charge also check system pressure
check coolant system and coolant fan operation
check high pressure switch
Monday, June 30th, 2008 AT 9:26 PM
