Washer pump, replacement parts available. What is the removal & installation procedure for getting to and replacing the washer pump?
May 7, 2008 at 8:01 AM
✓Experienced Mechanic
Hi there,
the pump will be a sealed unit and not repairable. I think on these they are fitted to the bottom of the reservoir, and if you unbolt the tank it will be easy to remove.
