1997 Honda CRV Thermostat
JOHNNYBURCHAM
Engine Mechanical problem
1997 Honda CRV 4 cyl All Wheel Drive
where is thermostat located
Feb 6, 2010 at 5:10 AM
  • 55,658 POSTS
Hello, the thermostat is located under the front of the intake inlet by the boot near the top of the transmission. Here is a picture for what it looks like to help you locate it.
https://images.2carpros.com/forum/automotive_pictures/12900_thermos_1.jpg
Also here is guide to help you change it. https://www.2carpros.com/articles/replace-thermostat Please let me know if you need anything else to get the problem fixed. Best, Ken
Mar 13, 2017 at 6:23 AM
ANONYMOUS
  • 0 POST
Can anyone tell me where is the thermostat located on this 2 litre 2 wheel drive petrol CRV and how to change it? The temperature gauge always seems to be low, so I suspect the thermostat is faulty. thanks
Mar 13, 2017 at 6:23 AM (Merged)
FAKHIR
  • 26 POSTS
hope it will help you.
HMAC300
  • 48,601 POSTS
chart is correct
TPHAMRICK
Engine Cooling problem
2002 Honda CRV 4 cyl Four Wheel Drive Automatic 72000 miles
After driving for about 15-20 min. The temp gauge will spike to the "H" mark. Then a few min later it will drop a little bit, than it will spike again. I check the coolent level and it is good. There are no visible leaks anywhere. Does this sound like a thermostat problem or something else?
If it is the thermostat then where is it located?
Mar 13, 2017 at 6:24 AM (Merged)
KHLOW2008
  • 41,812 POSTS
Hi tphamrick,
It depends on whether the engine is overheaing or not. A high reading with no signs of overheating might mean a bad sensor or gauge.
Did you check if the radiator fans are working?
