knocking sound when driving over bumps and uneven road surfaces. Had wish bone replaced 8 months ago. think the problem is the rubber damper/washer on rod off wish bone joint and attached to the wheel. rubber circular washer type washer that stops movement when turning steering wheel.The supplier is having problems with part identification. The top damper/washer is worn and I want to replace top & bottom rubber bush? need help with part name.
Aug 26, 2010 at 4:03 AM
