1997 Honda CRV Broken Engine Pulley
219,007 MILES • 4 CYL • AWD • AUTOMATIC
DANIEL FERREE
What is the probability that a broken crankshaft pulley was caused by someone who replace the timing belt a couple of months ago? If not that what else might have caused the pulley to break, causing damage to the shrouds and belts?
Apr 5, 2010 at 8:59 AM
2CARPRO JACK
  • 11,533 POSTS
The crank pulley has to be removed to do the timing belt, so if the wrong puller was used it may have been damaged.Depending on what broke, a loose crank bolt can cause damage as well.A couple months is a long time to go between the work and when it broke though
Apr 6, 2010 at 5:51 AM
