1997 Honda CRV
PHHUNTER
  • 1997 HONDA CRV
Engine Performance problem
1997 Honda CRV 4 cyl Four Wheel Drive Automatic
Engine stalls when hot outside, not the engine temperature. Also have replaced main relay.
Thursday, April 15th, 2010 AT 2:06 PM
F4I_GUY
  • 3,302 POSTS
When the vehicle stalls, check for spark. You will most likely find that it is missing. You will have to then diagnose the ignition coil and ICM. (Both are common failing items once hot)
Thursday, April 22nd, 2010 AT 7:10 PM
