1996 Honda CRV Crank Position Sensor
1996 HONDA CRV
194,666 MILES • 4 CYL • 2WD • AUTOMATIC
CHRISLUVSTAT
I had my car towed to autozone and had it put on the machine. It registered that the crank sensor was not hooked up. Can someone please tell me where do I find this on my engine. I have a picture of it but I can't locate it on the engine...
Mar 30, 2008 at 10:04 PM
If its a 1.6L try the left front of the cylinder head-
Mar 30, 2008 at 10:14 PM
CHRISLUVSTAT
I don't know much about cars in general. I have a 4 cycle. Front wheel. 2 wheel drive. I just need to know where the crank sensor is, but I don't know the part you are referring to to look at.
Mar 30, 2008 at 10:24 PM
but I don't know the part you are referring to to look at. The cylinder head is where all the sparkplugs at its the upper part of the engine
It registered that the crank sensor was not hooked up-Why didn't autozone just hook it up for you if its the problem. Something is wrong here-
Mar 31, 2008 at 5:07 AM
CHRISLUVSTAT
Auto Zone did not know where it was either they printed out a copy of what it would look like but everything in this engine is so compact that its hard to see. They are making the inside of the cars bigger but the engine area smaller which makes it harder to work in. I had taken that alternator out 1st time for me and that was so hard... Anyway guess I'll ask Honda dealer where this part is. Thanks for all your help.
Mar 31, 2008 at 10:50 AM
