1994 Honda CRV
168,000 MILES • 4 CYL • 2WD • AUTOMATIC
KIBARRETT
I gave my Honda CRV a tune-up replacing the plugs, distributor cap, wires, and rotor. Seemed to go just fine but now it won’t start. I checked everything a couple of time finally resorting to replacing everything with the original parts one by one. I checked to see if I was getting a spark, no spark.
Aug 12, 2010 at 3:29 AM
KHLOW2008
  • 41,812 POSTS
Hi kibarrett,
Are you sure you got it right? 1984 the CRV has not been manufactured yet.
Aug 12, 2010 at 3:43 AM
KIBARRETT
98 I'm sorry
Aug 12, 2010 at 4:20 AM
KHLOW2008
  • 41,812 POSTS
You need to perform test on the distributor.
At the Black/Yellow wire, do you have battery voltage with ignition switch turned on and while cranking?
If yes, get the ignition coil tested.
Aug 12, 2010 at 6:50 AM
