Transfer case O ring replacement part number needed
200,000 MILES • 2.0L • 4 CYL • 4WD • MANUAL
GPASTOR8931
Hi, I have a leak from the transfer case. I will need to replace the O ring and my question for you is, did you know the part number for that seal or seals? Can you bring to me? thanks
Dec 13, 2020 at 9:17 AM
  • 110,251 POSTS
I attached a pic below indicating the part number and price of the seal I believe you are referring to. Check it out and let me know if that is what you needed.
Dec 13, 2020 at 2:00 PM
GPASTOR8931
I’m not sure if that seal you show me is what I’m looking for. I saw some pictures and I think the one I need is thinner. check the picture please.
Dec 13, 2020 at 4:39 PM
  • 110,251 POSTS
That is the transfer input shaft housing O-ring. I looked and found what I believe is the correct part number. To the best of my knowledge, it is 91301-PH8-005. You can get them on Amazon and other places.
Please keep in mind, it will be important to confirm that once you get the part. However, I feel that is the correct part.
See pic below. I highlighted the part I believe you are looking for. Please confirm that for me. Next, when you reinstall the transfer shaft housing, make sure to lubricate the new o-ring to prevent damage prior to installing it.
Dec 14, 2020 at 7:06 AM
GPASTOR8931
Yeah, that’s exactly the part I need. I will take care about the o ring. thanks for your valuable help. Did you know if exist any torque pattern or sequence and amounts?
Dec 14, 2020 at 9:01 AM
  • 110,251 POSTS
For some reason, the torque specs are not listed separately. The only ones I found are in the attached pics. If you need the entire rebuild directions, let me know.
Dec 14, 2020 at 11:10 AM
