1997 Honda Civic Fast Right Turn Signal
CFY30
Hi All,
I have a Honda Civic LX 97. Started from this morning, the flashing frequency of the rear turn right light is abnormal, it is more frequent than the turn right light as well as the ticking sounds. Anyone has idea on this? Is something broken?
Thanks,
cfy30+
Oct 11, 2006 at 4:26 AM
BRUCE HUNT
  • 3,754 POSTS
Pretty cheap but I think there is a seperate flasher control for left and right signals. Replace the failing side.[/url]
Oct 11, 2006 at 6:31 AM
CFY30
Hi Bruce,
Do you happen to know where is the flasher control?? Is it accessible without lifting up the car?
Thanks,
cfy30+
Oct 11, 2006 at 12:20 PM
BRUCE HUNT
  • 3,754 POSTS
Simple way to find it is to turn on the 4 way flasher and follow the sound. Usually near the fuse box.
Oct 12, 2006 at 4:14 AM
Suggested Repair
Replace the failing turn-signal flasher for the affected side. Turn on the hazard flashers and follow the clicking sound; it is usually near the fuse box and does not require lifting the car.
Conversation Summary
The owner of a 1997 Honda Civic LX reported that the right rear turn signal began flashing faster than normal, with a faster ticking sound. The expert said left and right signals may have separate flashers and recommended replacing the failing side. To locate it, turn on the four-way flashers and follow the sound, usually near the fuse box.
