I have a 1990 Honda Civic EX model at 140,000 miles with the automatic transmission. When it is cold outside, usually below 50 degrees the transmission takes time to shift into high gear. Once the transmission is hot, shifting is not a problem. During summer months this is not an issue. I have changed the transmission oil with Honda's transmission fluid, as instructed by Honda technicians, but the problem persists. I drive on the highway everyday to and from work and most times it takes about 1 to 2 miles before the transmission is hot enough to shift into high gear. Shifting into other gears is not a problem, cold or hot. What do you think could be the problem?
Jan 13, 2007 at 5:33 AM
