2001 Honda Civic manual trans
CHEVMNSS
Transmission problem
2001 Honda Civic Front Wheel Drive Manual
when i engage clutch feels like i am in 3rd gear but shifter moves freely like no gears.shift rods going into case are moving
Jul 6, 2008 at 4:55 AM
KHLOW2008
  • 41,812 POSTS
Hi chevmnss,
Loose gear shift means the bushes are worn and it would not allow the first, second,fifth and reverse to be selected.
From bottom of car, try twisting the gear rod and see if it can be shifted into all the gears.
Check if the locking pin for the rod at trans end is worn, it will result in excessive free on the rod movement.
Jul 6, 2008 at 6:17 AM
